Let's see what everyone gets bed liner sprayed on!
Ryan698
Hey guys so I'm gathering some ideas for bed liner I'm looking at getting a spray in box, I'd like to do that plastic trim on top the tailgate and on the bed sides I was thinking doing my door Jams and even that spot when you open your door and have that plastic step peice that says all terrain the spot under it. what's your thoughts let's see what you guys have done!
Sent from my SM-G930W8 using Tapatalk
My aluminum skid plates are being sprayed this week. I plan to put them on over the weekend.
    Dom Colussi
    Dom Colussi
  • Who's Online   5 Members, 0 Anonymous, 594 Guests (See full list)
