Knock sensors
I have a 99 5.3 Silverado. I replaced knock sensors and harness. Every thing is plug in. Have fuel in rails. Have rough idle. Sounds like starving for fuel. Don't have a computer available.
If you spray starter around the intake and it changes the rpm, it's the gaskets. That's the easy check.
Sent from my SM-G920V using Tapatalk
Ok when I start the truck right away the rpms jump two 2,000. Then settle down. It will jump from 300-1000 idling. Been told throttle body sensor??
Wouldn't be surprised.. The TB getting dirty is fairly common on the 4.8, 5.3, and 6.0. anyone know how to test the TBS? Also have you cleaned the MAF Sensor recently?
Intake gaskets seem very plausible.
When I have replaced them due to lean codes, they never look obviously bad.
It doesn't take much of a leak to cause problems.
The gasket may look "good" but it cannot seal a warped intake manifold. Replace gaskets if any doubt or symptom
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
