Anybody now anything about Pergo/laminate flooring
mrowe8
I was hoping to do my kitchen floor this weekend with the Pergo Prodigy laminate flooring.  Does anyone here have any comments good or bad that I should consider?
what do you need to know?, my dad installs the stuff.
well, for a kitchen u prolly don't want carpet.  i don't know much about pergo, but personally i would go with regular wood flooring.
btw- have u considered tile?  it can be cold on the feet in the winter, but it looks good
Hey you said that about leather too and then you said leather was bad, geez paco, you're all over on the subject.
pergo is great stuff, it looks real, and is easy to install and lasts.
We are putting it down in my house this spring, it's some great stuff.
Since I can't get the pergo prodigy from my Home Depot I am now comparing the perpetual brand laminate flooring.  Anybody have any thoughts on this brand vs. pergo
I agree that wood may be a better floor but I am looking to do a 150' kitchen area in my starter home that I will probably only be in for another 2 years.............I don't want to spend the money for the hard floor for such a small project that I will not be enjoying for long
I installed a laminate flooring (not Pergo, but an equally good brand) two years ago on the entire main floor of my house (about 1300 sq ft). If you take your time, measure three times before each cut and clean up as you proceed, it can easily be done by the amateur. A smaller room such as a kitchen should be very easy, if done with care. After two years, the floor still looks like the day it was installed except for a few chips in the laminate where knives fell blade first. It does not scratch easily, but will if you are not careful. The cleanup is super easy. I fully recommend the product for the kichen or almost any room. :devil:  Go for it!
if you spend any time in the kitchen you don't want tile, it kills your back.
Pergo et al are floating systems, have a nice give to it.
If you're only going to be there for a couple of years I'd go with the tile.  It will be cheaper, use the 12" or 18" squares with minimal grout, and will hold up well.  Pergo holds up will, but it will scratch and chip.  If you have any kind of traffic or pets I would stay away from it.  Even if you put in wood at least you can refinish it/repair the scratches.
I went ahead and did the install.  It came out great and took me and another guy about 12 hours.  So far I have dropped 1 full beer can corner first to the floor and it left no *dings.  I am very happy with the process and outcome and would highly recommend it.  My untrained eye really would never notice the difference between laminate and real wood.  I have built several decks in the past but am sure that this install would be easy for the novice as well.  I have pictures if anyone is interested just email me at [email protected].
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
