I am having more abs problems. I have posted some stuff under the Bleeding ABS topic but thought I might get more help here. I was led to all data. I found nothing for the Tahoe. But did find a TSB for the Yukon.
The # is: 02-05-25-002 JUN 02
ABS - Wheel Speed Sensor Replacement Revision
Would this also work for the Tahoe? Please let someone have an answer. I don't want to call dealer until I have a little more backround info. Thanks a bunch.
Oh and what is happening is the ABS is kicking in just before the truck comes to a compleat stop.
Later,
Brandon
There is no difference between a Tahoe and a Yukon, other than badging....
For warranty work you do have to go to the correct "BADGE" as GM only pays that way...unless the owner has both Chevy and GMC shops (they can bill appropreiately on paper).
