Wheel Well Liners
New to the forum, already did the search function and found a few ideas, but I'm curious to know the following:
1. Who has installed wheel well liners (my '16 LT came with the "felt" in the well.
2. What brand did you go with? I'm looking for the OEM ones, but they're hard to find, I discovered the Husky liners here on the forums and wondering who has installed them?
3. Why did GM think it was okay to leave all those surfaces exposed to the elements?
FYI: I have a '16 Silverado Crew Cab LT
Easier to access to clean them, I've seen trucks with those full wheel well liners, they look good no doubt but I bet 99% of people don't take them off to clean behind them. Can end up doing more harm than good in the end, because they hold stuff like water and salt behind them with no where to go which can lead to rust. Now if you don't live where they use salt on the road then I would suggest them
I'll update my profile soon, but I live in South Florida, the truck will rarely leave the state.
Salt on roads? What's that? :P:P:P
They don't have the GM ones listed for 2016 but I doubt they're different from 2015. GM part# 22998786 is for the 2015's.
Fort Lauderdale nah that's not close to the BEACH...NOT! Hell the AIR is full of SALT
RT
