New to Forum and GM
gusman
Hi Everyone,
Long time Mopar and Dodge guy saying hi. The truck is actually my father's, but I'm planning on acquiring it in the next year or so when it's time to move my 2013 Ram Sport 1500. The truck is a 2015.5 2500 All Terrain SLT, 6 Liter. I had a diesel previous to my 2013 and without tunes and deletes these new diesels just don't have much value for me ($1500 to delete my 08 cummins).
Anyways, just joining to start reading up on these trucks as my knowledge is pretty limited, and hopefully get some questions answered.
Thanks!
    President Roberto
    President Roberto
  • Who's Online   3 Members, 0 Anonymous, 1,068 Guests (See full list)
