Morimoto HID kit 35w or 55w??
Hey guys/gals, I've been lurking for months here and finally decided to register and post. I've decided on the morimoto hid kit, but not sure if I should get the 35w or the 55w ballasts. Any input?
I have the 35 W kit and literally it is a "night and day" difference from the stock bulbs. Absolutely no issues with the kit since I put it in 6 months ago. My thinking is the 55 W kit may be too bright for normal street driving, but I'm sure someone with them, can / will give an opinion.
Be sure to check out Fodupot's (sorry if I spelled it wrong) installation video on you-tube before starting the job.
Thanks for the input. I managed to find some info on some ricer forums. Most are saying the 55w is a bit too hot for most projectors, and aren't great out in the open due to the cutoff. I went ahead and ordered the 35w ballasts. Looking forward to installing soon.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
