OEM Silverado Headlight Trim/Bezel Part #
crafferty
I'm currently searching on my phone and cannot find the part number for the OEM Silverado headlight trim for a 2014/2015.
Long story short, I had one crack on me while removing them. I ordered an aftermarket set from Amazon, had them painted and learned they will not fit (gap between the 3m tape and the face of the headlight. In my searches I keep finding articles about GM aftermarket offering paintable pieces but cannot find where they sell them. So any help would be greatly appreciated.
Sent from my SM-G930V using Tapatalk
Good luck with that. Last I heard they are sold with the headlights. Can not buy them separately
I was told you can't buy them separate from my local dealership. I believe I found the same thing you found with the replacement bezels on gm repair insights. It's interesting because it says they come with a distinctive part number but no one seems to know about them.
https://gmrepairinsights.com/2015/04/primed-headlamp-replacement-kits-now-available-for-full-size-2015-chevrolet-trucks/
https://gmrepairinsights.com/2015/10/some-gm-truck-replacement-headlamp-assemblies-now-paint-friendly/
I keep finding those links or articles pointing towards them but no products. It's like they came out with the idea and then cancelled it.
You can't buy them separate. I think the aftermarket ones are made to stick on over top of the oem trim.
Well that's asinine! It would be nice if the seller on amazon had listed that detail.
Is that the problem?
Yeah I didn't know your supposed to place this aftermarket trim on top of the factory. That's just dumb in my book.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 449 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
