Switching from Valvoline SynPower to M1 - Can it cause leaks/oil usage
I am thinking about switching from Valvoline SynPower to Mobil1 5W-30. I was using Pennzoil Platinum but was getting the cold start tick so I wanted to try a different oil to see if it helped quiet the tick.
Since using the Valvoline for about 3 weeks, I've gotten the cold start tick twice and it's been in the 60's. I thought about switching to Mobil 1 to see if it helps but I have read that it's on the thinner side of the 5W-30's and can cause leaks. Is there any truth to that or should I switch with confidence?
When I had my '98 I put 5W-30 in it and I switched from Quaker State to Mobil and never had a leak with either oil. Those people that had a leak probably had a minor leak that a thicker oil might not get through. At least if it does leak it's showing where a leak would have been in the near future with the other oil. Also the #s mean the viscosity at cold and then operating temps, so I doubt Mobil 1 is thinner than other 5W-30.
Go ahead and switch and don't think anything more about it.
I guess I'm more worried about burning oil since it seemed to drink it the last time I used M1.
I'll probably change it in the next week or two when I have time.
Switching to Mobil 1 I think you will still get the tick. It seems that from what I have read on here and a few other forums that the Mobil 1 users have noticed it more than other brands.
As for leaks you shouldn't have any problems since you have been taking care of your ride running a quality oil all along.
You can always try AMSOIL as well and see how it runs in comparison to the other oils you have already tried. If you want PM me your address and I can get you a quote on AMSOIL delivered to your door.
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 566 Guests (See full list)
