Newb
deweyg63
New to the site. Just bought a 15 silverado LTZ with the 6.2 All was good on the test drive and 250 mile drive home. A few days later I got the dreaded Chevy shake from 45-70 mph. Only does it after warming up and at a steady speed not while increasing or decreasing. Dealership is changing the torque converter today
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
