Need advice on 2016 Accessories and rock chip problems
John44
Haven't had to wash it yet, not suppose to for a couple days. And I took it to a Line X dealer.
If you don't mind me asking, what was the approximate cost?
$800 for Black or $1000 for color match. I didn't do the bumper but the estimate was $250 for Colormatch.
I'm assuming that's USD. That's not bad actually. I'm going to look into this. Thanks for the info and the pics.
No, I didn't have the running boards untill I got Line-x. Running boards will actually help. These boards aren't very wide, but rocks will hit the bottom of the boards and knock them down.
Finally fixed the problem. Color matched Line x the rockers. Loved the way it turned out.
That looks good! You can barely tell where the edge is... What did that run you if you don't mind me asking?
EDIT - Ha! Just read post #18
  • 5 weeks later...
You have a couple close up pics of that? Looks really good from a far.
I have the 16 z71 w painted front bumper. It is rock chips galore at 8k miles. Don't seem to have problems on the sides like u do.
I'm having the same issue on mine at 6K miles and I paid extra to have the paint sealed and protected (along with the interior and underbody), I'll see if chips are covered under that warranty, but I'm expecting it won't.
My father has the chrome bumper on his 16 and it looks brand new at 10k miles. I bet I have at least 10 chips that are all the way through to the metal below
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
