Nitrous
Personally I've never been too fond of having to fill a bottle or bottles for power, especially if it's only for a short time. Seems like a video game with the boost button or something. The only time I think it might be fine is for an actual race car where you spray nitrous the entire time you're going down the track in place of forced induction.
Depends how much you want/your goals.
Up to 100-125shot I believe you can do w/o a tune or more fuel
Anything above that would take more fuel/properly tuned for it.
Had a buddy run a 100 shot in his 5.3 for a little bit and boy was it awesome. As long as you (or your tuner) don't get greedy and are careful with the tuning, you should be fine with around 100 shot.
A basic wet kit can be used without a tune. As long as you stay within the parameters of the kits recommended shot size for a non tuned application. I've used it on cars in the past and never went over a 125 HP shot as the manufacturer of the kits instructions didn't recommend it. Never had any issues and I always used an MSD RPM window switch. Install was easy and it always worked as it was supposed to. Mind you the kit was hidden and all I had was an arming switch that was a fog light switch so it wasn't obvious. Hidden kits won many races :)
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
