2007 Silverado AFM or No AFM?
Hello new to the forums. I'm sorry if this already been answered but I have a 2007 silverado nnbs 5.3 and was wondering if it has AFM? It has no buttons for DIC so wouldn't know if it kicks down to v4 or not. Any help would be appreciated.
07 GMT800 or GMT900?
GMT900. I'm only asking because it's burning 1 qt of oil every oil change and I've read that afm tends to burn oil.
If it is a 900 series with the 5.3L like you said then yes, it has AFM.
So then the burning of 1 qt every 3-5k miles is considered normal correct?
My 07 Ava LTZ 5.3 had it ... and it burned about 1/2 quart each 5000 miles till traded at 142,000 miles
my guess
seems it just varies .... truck to truck
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
