Aftermarket Tow Mirrors
carsonj493
I'm looking at adding tow mirrors to my truck, specifically the new style ones. I found these on Amazon for a good price: https://www.amazon.com/gp/aw/d/B01N8P8KG8/ref=mp_s_a_1_15?ie=UTF8&qid=1480281334&sr=8-15-spons&pi=AC_SX236_SY340_QL65&keywords=2014+chevy+silverado+1500+accessories&psc=1
My truck only has power adjust and heat. No turn signals from the factory. From what I understand I need a separate door Harness for these tow mirrors in order to have all the options fully function since I don't have all the options from the factory correct? But is that all I need to do?
I was hoping someone could help clarify what exactly I would need to do in order to get the turn signal, courtesy lamp, and Amber clearance lights to work before I decide to buy it.
