Had HIDs for about 5 minutes
Hooked up some Amazon HIDs. Guess I didn't know I needed the relay. Luckily I called the company (Kensun) and they overnighting them to me free of charge. Anything else I should know?
If the HIDs work like they should and I like them, I plan on retrofitting.
For $70 it's worth a shot.
Buy the correct headlights. Those are going to blind the crap out of everyone on the road. Don't be johnny the ricer, do it right and legal....
Tyler
What do you suggest?
First is join a Facebook page like headlight junkies, and join hidplanet.com. They will be very useful in teaching you all you'll need to know. Secondly, you need a projector retrofit. You can do this by rebuilding yours, or buying ltz headlights, or aftermarket projector lights. Using an hid bulb in a reflector housing glares badly because the hid bulb emits its light differently than a halogen blinding everyone you meet. You can't adjust, or aim them to stop this from happening. Pnp (plug and play) led bulbs are just as bad in a reflector. Third don't waste your money on kensun, and other cheap brands. They aren't nearly as bright, and not nearly as reliable as theretrofitsource.com will be. I hope this helps you out.
What leads you to believe these lights will blind everyone else on the road?
The reflector headlights shine light into the back of the headlight housing which then reflects the light onto the road.
The problem with these is when it's reflected back onto the road from a brighter light, it's normally scattered light that typically blinds other drivers.
All the new GM's are projector style headlights where the beam runs through a projector and it projects out onto the road.
I'd definitely recommend getting the LTZ projector style headlight from the 14-15 Silverado models. Plenty of these at junkyards now for cheap.
Just so you know - that is illegal. There are very few HID bulbs that are DOT-certified for on-road use and none of the cheap ones are (Morimotos are but they have to be installed in projectors). Also they shouldn't be put into reflector housings since the housings are not designed to cut off the light (as others have already said).
I'm not trying to start a fight and I really don't care what you do - just thought you should know.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 414 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
