Pocket Jump?
UplandPa
Do these things really work? Any negative side effects? Thanks!
Not sure what model your looking at but yes they work for there intended purpose. Mine is rated for v6 or smaller and I got it to jump my 5.9 dodge. But the battery was not completely dead. So I would say they work pretty good. [emoji41]
They work fairly well. Best for a vehicle with just a dead battery. Not for continuous cranking when there is a starting problem. I have a couple of $50 - $80 jumpers. You need very good contact at the clamps.
My so has a 6.2 2010, I was thinking about getting it for him for Christmas, maybe I should just get him a good set of jumper cables! lol.
All fine until there is no car around to jump.
I've had a couple of the halo bolt ones. They work with a fully dead battery. The one I keep in my truck in the tool box though is booster PAC es2500
The small ones are good but this thing has last over a year on 1 charge and been used 10-12 times.
Yea... I was thinking about the no other vehicle nearby dilemma! Thanks!
