Anyone found a solution for this yet? Temp gauge drops to bottom, fans kick into fail safe mode and runs after shutting vehicle off. Also what may have ties with this- the AC is not working.
I did not. Although, I don't feel that this is imperative due to all the reading I've done on this issue. Tons have used OEM and some have used generic brand but have the same results at times.
I reluctantly, bought a new battery ($230) today and replaced it. The one I had on it was reading as "failed" even though it would crank and run fine. So we will see what it does.
Also what may have ties or may not, the A/C wasn't working and I had to recharge it today as well. Before charge it was at 7psi, after charge 32psi and working.
    novdelta27
    novdelta27
  • Who's Online   5 Members, 1 Anonymous, 628 Guests (See full list)
