08 Yukon No Start Issue
Wife was shopping yesterday and her car wouldn't start. We had it towed home and checked codes. It's throwing P023F and P069E. Both are fuel pump related. before throwing parts at it I decided to test some things and I found that the fuel pump relay is not getting power from the computer.
I'm getting constant power to pin 30 and constant ground to pin 85, but at key on or crank there is no power to the other side of the relay. Now I'm thinking ECM but I'm not sure how to test for it..
Does it turn over? And get spark? . . Then there is a pretty good working electrical no system . . If not, check the front side electrical first.
You can bypass the relay (pull it, and put a spaded wire into the socket - check socket wiring first.
If this works, then check wiring from ecm to relay before condemning the ecm.
Sent from my XT1053 using Tapatalk
Yes, it turns over. I would assume it gets spark. pressure reads zero at the fuel rail.
I thought about jumping the relay but not sure which socket to jump to. I would assume pin 87 but afraid that I might fry something if wrong.
Well, I jumped the two pins and it still wouldn't start. I'm confused now.
As I understand it, when the key is set to on, the computer senses this and sends a signal to the fuel pump to run for 2 seconds to pressurize the fuel rail for starting. Once the key is set to crank/run, the fuel pump stays on. So, when I turn the key to on, I should get power to pin 86 which will close the contact and get power to pin 87.
Hhmm, now chasing two things.
1) need to check fuel pressure, could be pump or filter.
2) need to check spark and sensor connections.
Have you tried to pull codes to see if any history set that might clue in?
Yes, the relay has a coil in it attached to the switch.The coil is energized via 86, pulling the switch closed allowing power to flow from 30 to 87.
Hope you checked the fuel pump fuse.... sometimes the fuse may test good on the top test points but may have corroded tabs. Pull the fuel pump fuse and flip it 180° and try it again.
Appreciate the responses so far. I dropped the tank today and learned a couple of things about this vehicle. I will explain these so anyone else searching for this might save themselves some time.
First of all, even though there is a relay clearly marked fuel pump in the distribution panel, it is not used on this vehicle. It has a fuel system control module mounted on a crossbar at the front of the tank. I spent an entire day chasing a problem that didn't exist.
The other thing...since the fuel system is controlled by the FSCM, the fuel pump does not fire up for 2 seconds at key on to pressurize the fuel rail. After dropping the tank I spent a couple of hours trying to figure out why I was not getting power to the fuel pump at key on. Finally, on a whim, I had my son try to crank it and the test light lit up. The real bitch of it all was the damn thing started. My assumption is that jostling the fuel tank around made the pump start working again. Either way, I'm putting a new pump in it tomorrow. I'll be damned if I'm going to put it all back together just to lay down on me again in a day or a week.
So there you have it. My gut initially said fuel pump. The DTC codes said fuel pump. My wanting to test some things first ended up costing me two days of frustration and wasted time. I should have her back on the road tomorrow. Could be worse I guess.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
