Contest
watz
I search for deals all day :cheers:. I think we should start a thread to see who can find the best deals...
I find that Cheap! has the best deals so far.
Mickey thompson tires on 16x8 classics for under a grand... can anyone find better?
(This will be good for all of us buying parts :withstupid: )
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
