A new menace for the road.
pacodiablo
I am 5 days away from having my conditional permit. The driving instructor said I was much better than most and that my defensive driving was good...people in NC...watch out, Paco is about to hit the road. :withstupid:
Congrats :withstupid:
I don't think I learned a thing in Drivers Ed. The second day I was in there the teacher said, "you must be the clown in here. Thats ok, I've got you figured out son." Best class I ever had.
my brother is getting his license tomorrow
:withstupid:
a few days ago he said "so when can i drive your truck"
um NEVER! :cheers:
The only think I learned in my Driver's Ed was this...
"Speed does not kill, the instant stop does"
:withstupid:
:withstupid:
I do remember a guy with State Farm comming to talk to us. Someone asked him why boys rates are higher than girls. He said girls have wrecks leaving the school parking lot, and boys have them doing 120 down the highway. :cheers:
Whats a "cnditional permit"?
I sit like VAs Learners permit"? where you can only drive with a lisensed adult in the car with you?
Same deal. We have a "graduated license program" which basically screws me over because of s**tty drivers until I am 18.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
