Over 15 volts
Willborio
Recently my voltage meter has been showing up around 16 volts and it don't drop down. Today when I started it after it was turned off for about 15 min. I got a click then it started fine. But it also didn't start with the settings I had the heat to. And there was no sound on the radio. It's an aftermarket radio with the wiring harness to retain all factory controls and functions. I've never had this problem before and noticed the high voltage after this happened. It was on for half an hour and the volts never dropped. Is the high voltage due to a bad regulator. There has been a constant noise under the hood since it got cold. It seems like the alternator is in a constant state of charging. Even though the battery when the truck is off shows good volts. It's an 09 avalanche ltz
The voltage is controlled by the computer based on battery charge, system load, etc.
My volt meter has been reading high on most of my drives because of the hard cold starts and I run my heated seats, A/C, and my headlights were on.
You need to check the voltage you are getting to the battery, with a multi meter, with the truck running to see if you are actually running high.
Also it sounds like your battery may be heading out... might want to have it tested using the Cold Crank test and see if it passes for what it is rated for.
If the sensing wire (whichever one they use) is corroded, it can cause this issue too. The computer will think the battery is low, and give the alternator full duty cycle.
Thanks guys I'll check the battery tomorrow and see what I'm getting athe the battery when running. I do run the heated seats the entire time it's on. But what worried me was even just in park with no heated seats on or lights since it was in park it stayed up over 15. It normally drops down to 14 and won't move from there when I'm driving except when it drops down.
On 2 vehicles just this week I've seen 15.12v running on my scan tool, mine being one of them. It stays there for a bit, then the computer eventually dials the duty cycle back a bit. After some time passed mine was down to 13.8.
It's normal for it to stay high initially - it should dial the duty cycle back over time as the charge comes up.
Yea it was doing that originally. But much higher currently than before. Originally it would be about a quarter inch past the 14v. The last couple days it's been more than half way to the 16.5v mark. But I just went out to fiddle around with it. And noticed the positive terminal was very loose. To the point I could have just popped it off. I tightened it up started the truck and I was just past the 14v the meter was showing me a steady 14.78 when I looked on the dash it was in what I see as normal range just past the 14v. I'm guessing the extreme cold to warm over the last few weeks here in northern illinois was the culprit. Probably got it just loose enough I wasn't getting solid contact.
Also the battery was reading 11.8 after sitting in the cold garage the last 24 hours and not being started. So it seems I should have checked the connections first then asked for help. Lol
Well, at least it was a FREE fix! These days those are hard to come by!
Glad it's resolved. :thumbs::cheers:
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
