2003 Silverado Not Starting Up
Hello Guys,
My truck does not want to start up, i turn key and starter turns but engine doesnt start. I switched out the spark plugs thinking it was maybe a bad spark plug because about a week ago the truck was loosing power when I would step on the gas until 2 days ago that it didnt want to start on at all. What can I check from here ? I tried looking for the gas line nipple on my truck to see if it has enough pressure but I cant find the nipple. What else can I check ?
^^^ X2.
Change the fuel filter that is located on the frame rail. Use either a Delco or Wix filter, nothing else.
