01 silverado 1500 ls2 swap battery light fix?
As the title says I'm looking for the correction for the battery light in the (dic)... ls2 swap out of an 05 gto... used a stand alone fast setup...need to get rid of the red battery light in the (dic)...anyone have schematics of which wire to the ecm controls the information Center battery light? Factory ecm/bcm is still present and functions bit I took alot of wiring out of the factory harness... so I need to know what wires at the ecm connectors are involved with that circuit....any help is appreciated
Thank you,
Alden
Trying to make amends here to my earlier faux pas. Hope this helps! Pin 20 is Battery voltage, pin 2 is 12 volt reference but I think that's an output.
Screenshot%202016-12-28%20new_zpsg7b5fyn
