Bought the Salviana Silverstars....
middle of july they will be coming out
I wouldn't say its a HUGE difference. But its sure is brighter. I like the look of the white light too!! :D
Mike
GOod prices on e-bay....Wallmart was not bad either!
MIke
I put them in my low beams and I really like them. Visibility is improved...especially during a night rain.
Now I just have to put them in my highs and get a headlight booster kit with the 4 beam high. :D
I am considering some of the silverstars, how much did it improve your visability at night ?
I put them in both low beam and high beam, and it did improve my night visibility. Anything with a reflective property (highway signs, etc.) really seem to pop out now. :D
I'll be interested in the fog light bulbs, too, when they come out.
Mike
I have the low beams. Visibility is somewhat better, especially the reflection from road signs.
But, the light pattern doesn't seem to be as spread out
(left-to-right), or as far out ahead as the original light. Don't know why that would be given the lens is the same.
I've ordered the Sylvania HID conversion kit and hope to get it soon (had to save up $ for a while). I'm really looking forward to that and will report the results.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
