Wheel Spacer
I been searching around with no luck with the setup I have. Looking to do bora Wheel spacers with my Bilstein 1.8" leveling kit. What is the largest wheel spacer I can run without trimming anything on my truck. I have 275/60/20. I am also hoping not to trim my studs. Thank you for the help
1.75 to clear studs in most cases. You might rub at full lock in reverse, but I never rubbed going forward.
Sent from my SM-G930V using Tapatalk
Is that what you ran on your truck. Ive read your build but I must of missed the spacer size
I ran 1.5" with oem 20" wheels before going to 17" wheels. If you have pockets on the back side of the wheels, you can run 1.5".
