MOODDDYYYY
watz
I have my shee up for sale at a MX track. Last night some kids decided to take it for a spin and ripped the ignition out of the quad stole my eye ball light covers.... I have insurance but big deal the parts cost less than the deductable, could be worse. But if your going to steal something take it! now I have to fix it just to sell it, which makes me more moody!
***Side not the bastards that stole it burnt the heck out of themselves on the exhaust :D to bad their old jeans are stuck to my bright chrome pipes :thumbs:
I stopped some guy on a crotch rocket with a temp tag on the back once and got to talking to him after seeing his legs bandaged...rested them on the pipes just one time. :D
A guy on a crotch rocket pulled over? They sure don't around here.
Some dude in a crotch rocket was working on poping wheeles out in front of our house the other day. IT was rather comical. He about dumped the bike 2 times.
I'm not a bike fan.......
Sorry to hear about your busted up bike, good luck getting it sold.
Well it was in the city, and with the way others drive there, he would've been hit by someone had he tried to run. But like I also said, with the bandages on the legs and the temp tag...he's a newbie. Haven't had to chase a bike yet.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
