CREAKING AFTER LEVEL?
scott19677
Hey guys I just had a 2.5 level done on my truck a few weeks ago and since then there is a "creaking" type noise coming from the front end when turning the wheels when either stopped or moving slowly like turning in a driveway. It has done it from the time the level was done. The level kit was a RC 2.5 front only and truck is a 14 Z71 w/aluminum control arms. Thanks in advance guys
Scott.
have you had it aligned?
did you make sure all the bolts were tightened to the proper torque specs?
I had small noise and found one bolt that was loose
Yeah. Had it checked twice for loose bolts and aligned twice by the shop that did my level and installed my tires. I going to take it to another 4X4 shop tomorrow as I can't really work on it myself right now. Trying to get over knee surgery. Sucks having to watch someone else wrench on my stuff.lol
