New Member first time Chevy driver
Zandrew
Hello! I purchased my 2000 Chevrolet Silverado 1500 4x4 Z71 about 5 months ago and have loved every bit of it. I will probably never go back to any other vehicle than a GM truck. I have taken it offroading twice and drive it everyday. It has its problems but I knew it would take some work. Its in pretty good shape for a 17 year old truck but the previous owner has messed with some questionable wiring and a few modifications that I am working on fixing. Ill most likely be on this site to figure out some of the "special" attributes and ask for suggestions. Im currently working on replacing the front wheel bearings and then some major replacements in the rear differential. Thanks for listening hope to see you in the forums!
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
