Nitto trail grappler noise
bigchevyz71
I just got a new set of trail grapplers and I'm not used to the new tire noise, are some new vibrations part of what come with these tires? Like vibrations under the truck in front? Thank you.
It's called "lug thump" and the coarser the tire tread or a little feathering and the more pronounced it will be.
Sent from my SM-T350 using Tapatalk
Ok so it's just the tires?
If it just came on with new tires, most likely.
Yeah I haven't heard it until I drove on the tires a little bit.
I'd have to say, without even knowing what the tread pattern looks like, anything with the name "trail" is going to be far more aggressive than a regular street tire, and, with that, you get more noise.
Everything's a compromise. Give up a little comfort and quiet for alot more off road traction. Just like dedicated snow tires - work unbelievable in the snow and ice, but fail spectacularly on a hot summer day.
Agree.
More than likely.
Can't say 100% since I'm not there to hear, see, feel the noise and movement of the wheel, but if the noise wasn't there prior to the tire change, then I'd say there's your answer.
More than likely.
yes it started with the new tires I had some lift put on professionally but I don't think that has anything to do with it. Thanks!
Trail Graps are some of the loudest tires I've ever been on.
Sent from my SM-G920V using Tapatalk
I don't understand all the hype for Toyo or Nitro tires.
I had nitto trail graps and they honestly weren't that loud in my truck, I've heard other tires that were much louder than mine, when getting mt's there's going to be some noise and vibrations but it's worth the aggressive look imo.
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 629 Guests (See full list)
