DiabloSport i2030 speed limiter off.
Grjfer
I installed the canned 87/89 octane tune and turned off the speed limiter. Finally got to a chance to open the 5.3 up today. Right about 98-99 mph she fell on her nose like the stock speed limiter had kicked in. Keeping the throttle pinned it picked back up and hit 100 as I ran out of room.
Does this seem right? I just figured with the speed limiter off it would just continue to climb.
My speed limiter is off and I can make it to 119 before it cuts off...this is achieved with diablosport 1000 on a 2015 Silverado w/ 5.3...
I would uninstall, update then re-install...if that doesn't fix it then contact customer support or diabLew.
Weak... 130 easily
I think it will do more than 100, I just ran out of road. My concern is that you can feel it hit the stock limiter, then it goes ahead and pulls from there.
I've done 125 in my old 02 leveled on 33's, that made me uncomfortable enough to not do those speeds in a truck again lol
Sent from my SM-N920V using Tapatalk
OK, so here is an update date. On the Diablo forum I read a statement that said the is bug in the canned 87/89 octane tune and to add that tune from the advanced menu. I did a factory restore, then added the 87 tune from the advanced menu. Still using the same parameters as before. Firm shift speed limiter off.
Test run on same stretch of road it pulled all the way to 102 before I ran out of room. So all is good.
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 525 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
