how else to stiffen things up?
I have firestone airbags and love them. Did the install myself.
Many people I know put way too much PSI in them which makes it like a pogo stick.    When I put a load in my trailer, I adjust the air pressure so the squat is lifted back to exactly what it was on stock height and that's it.  Sometimes it takes as low as 10 psi. As high as 40psi. It varies every load, I find measuring the fender on each side (I have both of my rear bags individually filled) the best and easiest way.
  • 1 month later...
  • Replies 49
On ‎2‎/‎6‎/‎2017 at 7:42 PM, Jon A said:
Nonsense. Sumo springs and Timbrens are certainly better than nothing, but they don't compare to airbags. Timbrens add a lot of capacity but not until the suspension is compressed substantially which affects ride and handling quite a bit. Sumo Springs for these only "add 1000 lbs capacity" which isn't much and only when the suspension is largely compressed so they do a lot less.
If the OP can't swing a new truck this year, he can dramatically improve his current rig by replacing the Sumo springs with a proper set of Firestone/Airlift bags. Fill them to 50 psi or so, hook up to your trailer and see how it feels. I'll guess right now you'll feel fine with the truck like that for another year. And that's only 1/2 of max....
Yes, shocks can also make a noticeable improvement but the better ones are more expensive and if you're trading in the truck in a year you may want to avoid that. Do the airbags first and see if you feel you need anything more after that.
The main problem with your suspension right now is soft rear springs--the airbags fix that problem very well and they're relatively cheap.
Look up the RoadMaster suspension. had it on my trailer I just traded in. Watch the video, and you will buy them. I also have some for sale. Easy to install and once installed no adjusting needed.
  • 1 month later...
16 hours ago, Revan said:
I would put a set of Lt tires on and get rid of the p rated ones
always run LT tires. 70psi
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
    • It's like saying Bill O'Reilly is "just" a journalist.         Lauren Fix, widely known as "The Car Coach," is a prominent automotive journalist, television personality, and self-identified conservative. She is a frequent contributor to right-leaning networks and platforms, offering commentary that intersects the automotive industry, consumer economics, and conservative political perspectives. [1, 2, 3] Media and Commentary Network Contributions: Fix serves as the National Automotive Correspondent for Newsmax and is a frequent guest on Fox News and Fox Business. Video Platforms: She has contributed to PragerU, where she has hosted videos critiquing government mandates on vehicles. [1, 2, 3] Core Positions Anti-EV Mandates & Fuel Policies: Fix regularly critiques government subsidies and mandates for electric vehicles (EVs), framing them as impractical and burdensome to the average consumer. She advocates for consumer choice and supports traditional internal combustion engine vehicles. [1, 2, 3] Economic Analysis: Her commentary often emphasizes the impacts of fuel prices, inflation, and federal regulations on drivers. [1, 2, 3] Political Alignment: On her public channels, she actively supports deregulation, "drill baby drill" energy policies, and the removal of government restrictions on auto sales and manufacturing. [1, 2] For analysis from Lauren Fix on how consumer automotive choices can align with political leanings:
    • Wouldn't swapping out the original AFM/DFM parts for a complete Delete Kit be the best route to go if one could afford to go that route?
    • It comes with directions but yes, generally, it's the same.  Also, get you the dipstick stuff to install dipstick so you have one.
