Hello all. I'm planning on doing the muffler delete very soon and I'm debating whether I should remove the flapper too or just clamp it open. I'll be using the Range AFM module so no V4 to worry about. What's everyone's opinion on this?
if you have the V4 mode tuned out, then remove the flapper. If you do not, leave flapper.
I just went through the muffler delete process. For me it sounded good/deep but it was loud with flapper clamped open and any accleration. On idle it had a good clean rumble. The unclamped flapper made a strange flutter sound so I had to remove. It was loud enough my wife and neighbors could hear me come from slightly down the street and on highway you definitely had more cabin rumble noise even without v4. So I removed flapper and resonator also and added back in a Magnaflow 12909 22" muffler. This seems to be more my style. Nice low growl, calm in the neighborhood, but nice when you lay into it, I barely have any v4 chopper noise with this setup. Everyone on this forum has a different level of what is acceptable sound and for some it will never be loud enough. To note as well I have an AFE CAI on the truck and feel it does add to the sound as well. Keep that in mind if you plan to upgrade your intake as well. Good luck on finding your sound.
Sent from my Note 5 using Tapatalk
"Everyone on this forum has a different level of what is acceptable sound and for some it will never be loud enough."...
Well said GMC_SD!...
Edited by Crstfr
Had it done this morning. Had them remove the muffler and flapper and left everything else the way it was. Sounds amazing in my opinion! It's exactly what I was looking for. Thanks everyone for the input.
You should post a video so we can hear it?
I did leave the resonator. Removed the muffler and flapper and put a straight pipe in place of them. I can't say enough how much I am pleased with this. I'll try to get a video up soon.
How is the interior sound? how about when it switches to v4?
Bam. Lock the thread haha.
My friend owns a muffler shop so I tried 4 different configurations and this is 10000% accurate.
This is true!
Interior sound is mild. It sounds about the same as the stock exhaust on my wife's 07 Yukon Denali with the 6.2. For some reason GM decided these newer vehicles needed to be quiet. I felt like I needed to undo that haha. Under normal driving its barely louder than stock inside. Under acceleration you can definitely hear it. I installed the Range AFM module to turn the V4 mode off. When it switched to V4 it sounded terrible, but I removed the flapper with mine as well.
video please!!!
Yes please post a video!
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 507 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
