Air intake and spark plug question
So I changed my plugs 01/28/17 and now my truck is cutting out. I use the same kind of plugs every time so I do not understand what is wrong. My wires are relatively new so we are good there. I use AC DELCO Professional Platinum, (gap is .60) Should I try a different plug because these kind of plugs seem to last only a few months for me before they are burned out?
I took my truck to a friend and he broke these little metal clips that hold one side of my air intake on (which is on top of the throttle body) so now the only thing keeping it sealed is the plastic wing nut. It seals it enough to not throw a code but when I turn the engine off, smoke comes out of the air intake (which is on top of the throttle body). Where do I go from here. Do I get a K&N Air Intake System or can I just replace the whole intake system with an OE part. I checked O'Reilly's and they did not have that piece so I need some advice from yall here.
I appreciate all of your help.
Post pictures of the air intake and of the old spark plugs you removed.
Spark plugs should last 100,000 miles easily unless you have another issue.
It sounds like you have other issues here, unrelated to the plugs. Do you have an aftermarket intake? I have an 06 as well and it doesn't have the plastic wingnut, or metal clips you describe.
You shouldn't need to change plugs every few months. You should be getting no less than 100k miles on a set of plugs. In fact, it should be closer to 200 K miles. Some are even going more than that.
Just use the original spec plug, as they work as well as anything. I think they are iridium IIRC......
Not sure what else is going wrong here for you.
You should not have smoke coming out your air box or intake.
Sounds to me like your truck is running too rich. Your injectors might need cleaning or replacement.
Now if air to fuel mixture is off that can be an issue as well.
I personally am not a fan of cold air intakes on these trucks, Ialways got a to lean code.
Fuel pressure psi is 60. No codes and 94k miles but I bought it at 83k in March of '16. Engine size is 4.3 V6. Yes, it is my air box. I do not have a cold air intake but wondering about it. My truck idles well and is okay driving if I do not hit the gas medium to hard (interstates, etc). I have no clue about this problem, it makes zero sense to me after putting over $800 of new parts on the fuel rail and keeping the engine maintained.
It has been suggested that I use Fuel Injector Cleaner which I will do. Also to put a little 2 cycle oil in the gas next fill up because ethanol dries out the oil in the fuel system so I will let everyone know how this works.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 353 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
