HID, LED Reverse, and LED License Plate Bulb Install
I hadn't had much luck finding bulb sizes for my wife's 2017 GMC Acadia online, so I thought I would do a short write up on my install. The 2017s use a 9012 headlight bulb for all trims besides Denali, as that is the only trim that comes stock with HID bulbs (we have a SLT1). I had used theretrofitsource.com previous to do a HID install on my 2015 Silverado, and I knew they had a kit specific for Sierra's that use a 9012 bulb. I spoke with the customer service team at The Retrofit Source(TRS) and they told me I would be best off trying that system as it comes with the necessary relay/capacitor link to not throw any codes with the new headlights. Here is a link to that system: https://www.theretrofitsource.com/hid-systems/application-specific/2014-sierra-morimoto-elite.html
That being said, the install was fairly straight forward. The headlights were very easy to get to. You are required to drill a hole in the dustcaps as the wiring for the HID system has to go through them (TRS provides rubber grommets to make this a water tight seal). I mounted the relays to the back of the drier side horn mount. Both driver and passenger ballasts were zip tied to a cross members under the hood and the igniters were zip tied to the ballast mounts. As for wiring, I tied into one of the fuse block legs for the positive and right to the negative post attachment for the negative. The capacitor also requires a ground and I attached it to a bolt on the cross member the ballasts are attached to. Below are pictures of the install as well as some before and after pictures of the light output.
I also switched out the reverse bulbs and licnense plate bulbs with LED. Pictures will be in subsequent replies to this post.
Changing the reverse bulbs was somewhat easy, though a 2nd set of hands is a big help. There is only one 7mm bolt you have the remove in the tailgate door panel, the rest are just clips in the door. The bolt is under a cover in the inside tailgate pull handle. You also have the disconnect the tailgate close button wiring harness to be able to remove the door panel. The bulbs are easiest to remove with needle nose pliers, they come out by turning counter clockwise. I am very happy with this upgrade, the LEDs put out a significant amount more light than the OEM bulbs. Here are the bulbs I ordered: https://www.amazon.com/gp/product/B01I3OTWQ2/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
Thanks for the write up, we purchased a 2017 Denali and could not figure out how to get into the reverse lights. I was hoping there would be some Mod threads on here like for sierra but maybe with time. Would love to find out how to have the fog lights come on with the auto headlights. Thanks again for the links.
Thanks Bigsby!!!! I am going to be doing the same very soon. You don't happen to know how the remove the Headrests on the 17's do you? Not like yrs. past with a paper clip....
No, I haven't tried to remove the headrests.
  • 4 weeks later...
Okay, I got the Headrests out.
- Raise the headrests up
- Unscrew the black caps on top of the Seats/Bottom of the Headrest Posts
- You will see a pin that has small round hole
- Pull it back and lift up on the post, then do the other side
- Done
  • 1 year later...
Thanks for the exhaustive write up and pictures. I was wondering on the reverse lights: is there any way to change the reverse light bulbs without having to remove the entire tailgate cover? I have an Acadia Denali, and I have two small plastic covers in the top third of the hatch, right where the brake light assembly is. Can I access them through there? What was your experience? Thanks!
  • 7 months later...
Thanx for the post & pictures.  Very helpful.  I decided to install the recommended license plate bulbs.
I was disappointed to find that the original bulbs already had some corrosion on one contact wire on side of the bulb.  The bulb wire on one bulb had nearly corroded off.  It took some doing to clean the socket contacts.  I put some Noalox inside the socket & on the new bulbs.  I then coated the sockets O rings with some silicone grease.  Even with the effort, I am not convinced that electrical contacts are secure.  I expect to have to replace the socket in the future.  I hope Springhill has addressed this issue & is now including anticorrosion grease to these bulbs and sealer on the O ring.
My '18 Acadia has ~12000 miles & I live in SE Michigan.  -Bob
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
    • I was around and remember that era very well, so I'm calling b/s on that statement. If they were that bad no police department or taxi company would've bought a single one ... but they were used in both services (and fire) for DECADES. They were bulletproof and proven. Even the early 21st century ones weren't too bad! The early models were legendary.   Mine is proof, but people like atlas are blinded by agenda and refuse to believe facts right before their very eyes.   Even decades after they were built, a new generation started driving them, posting all their builds and shenanigans on Grandmarq.net and Crownvic.net. The failures would show up then, since they all were deep past 100k-150k miles by that point, and younger drivers tend to be a little aggressive, especially with vehicles than can lay a one-tire fire for as long as you hold your foot in it. They've more than proven themselves over the decades.   The only thing that'll really take them out is road salt. The bodies and sheet metal were garbage. A victim of the cheapout FoMoCo and GM have been partaking in before then, and since.   Today it's the stuff that counts - the undercarriage that rots away first!    GMs Caprice was no slouch either. Reliable as a stone ax - the opposite of what they build now.
    • Let me know how your vehicles do in 10 years. You don't know ******, kid. 😂    There's a reason that Panther platform was used as police, fire, and taxi service for DECADES ... long before you were born, apparently.
