Towing mirrors help
Samuel Lara
Recently purchased my towing mirrors for my 16 silverado. Got the heated and power options to work. Hard wired turning signals, spotter but cant get the dam clerance lights to work. What wires am I supposed to be hooked uo too?
Thanks in advance
Thanks in advance
If your wiring it yourself I would tap into the park lamp.
Thanks in advance
Can you explain how you hardwired? Did you run wires through the door boot? Where did you land the turn signal and cargo lamp? The amber lamp is your park lamp and tied to the park lamp circuit. If you have a 2016, your door hinge connector should already be pinned.
