1 year maintenace due
It’s time for my 1 year maintenance. This weekend I'll:
1. Change Fuel Filter
2. Grease front end (should be doing every 5K oil change)
3. Check differential oil level (rear changed at 1000 miles)
4. Lubricate door gaskets (any suggestions on what to use here)
5. Wax (any suggestions on what to use here)
Have I forgotten anything?
:sigh:
I typically do this at the 30,000 mile mark, not on a yearly basis.
This gets done with every oil change. There are a total of 11 zirks.
Again, I changed this fluid, along with the front diff, transmission, and transfer case fluid at 30,000 miles. I went with the GM's suggested fluids here.
I do this whenever they start making noise. GM recommends a tube of dielectric grease that you can only buy through them, and it costs almost $15 for a tiny tube of it. Go to Wal-Mart, and buy STP Silicone spray. It looks like a WD-40 can, but the grease is odorless and doesn't leave a greasy mess. It also won't drip. Be sure that on the top strip, (the one that runs along the side of the windsheild and across the edge of the roof) that you make sure to lubricate both sides. I actually pulled mine off, soaked both sides in the silicone spray, then put them back on. Be sure to wipe them off first to get any dirt off of them.
Different people suggest different brands here. I typically do mine every 2-3 months, and I prefer to use Meguiar's Gold Class. It's a little pricy, but it is good stuff.
Dieletric grease is available at any auto parts store, its used under ign modules, in spark plug boots, and on weatherstripping :jester:
cabin air filters
Pep Boys has Purolator with both filters in the box for $10
Was just gonna say that, did mine the other day :jester:
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 720 Guests (See full list)
