Will These Tires Rub?
gderose
I have a 2015 GMC Sierra with a 2 inch leveling kit. I'm wanting to get some Toyo at2 Extreme 295/55r20 and I was wondering if this tire will rub anywhere? What about 305/55r20?
Many questions on this with tons of info on specifics, try searching to get a better read on the answer. Tire brands, leveling kit, wheel spacing, ect all matter which will be covered more thoroughly in other topics. Where one person might not rub with a nitto another might with a General and so forth...
Tyler
I have spent many hours researching this same topic. I have changed my mind repeatedly on which size to run and different specifics. I think i will go with toyo extremes in 295/55/20 with fox 2.0's. The fox's are on order with MRT. It is widely accepted that 275/60/20 is the "safest" size to run with no rubbing.
Take a look at this thread
http://www.gm-trucks.com/forums/topic/169320-calling-all-leveledlifted-trucks-with-all-terrain-factory-20s/
I ended up getting the 305/55r20. There's no rub except for when the wheels are at full-lock where there's a slight rub. Also, I meant to put that I have the 2.5 inch level, not 2 inch.
