Bak Industries Revolver X2 Review/Recommendation
krazykarl
The Bak Revolver X2 was at the top of my list when deciding which cover to buy for my 14 Silverado. I have a few friends that purchased other Bak Industries Flip covers in the past and they raved about them as well. I liked the sleek appearance and operation of the X2 over the Flip style covers. I also wanted a cover that would offer the ability t
o secure the contents of my truck bed with locking tailgate.
The Bak Revolver X2 seemed to be packaged fairly well, however, upon opening the ends of the rails were bent. I reported this to Tonneau Covers World who promptly shipped a new cover to replace the old one and arranged to have the damaged one returned at no charge. Unfortunately, the second cover arrived with similar damage. Tonneau Covers World shipped a third cover and picked up the second damaged cover again at no charge. The third cover had minor bends in the ends of the rails that aren't supported until installed on the truck. Tonneau Covers World said they would arrange to send me new replacement rails or discount the third cover. I decided that I could live with the minor blemish and was able to straighten the ends of the rails.
I can't say enough about Tonneau Covers World Customer Service! They worked with me and were understanding of the situation. It wasn't their fault that rails were arriving damaged. I feel that Bak Industries could improve their packaging a little to protect the rails. Hopefully this gets back to Bak Industries as I am sure they would like to eliminate this issue for future customers.
Installation was easy and fast. One handed operation is a huge benefit coming from a snap on cover on my last truck which was nearly impossible to roll out and snap on when it got cold outside.
Pros: Easy install, One handed operation, Secure, Sleek appearance, Nearly flush with top of rails when installed, Operate tailgate without opening.
Cons: Damaged during shipping, Need to keep ice and snow cleaned off of it to open during winter months (Similar to other covers).
I would highly recommend considering this cover as I feel it is one of the best on the market.
Tonneau Covers World has a great website and exceptional customer service.
https://tonneaucoversworld.com/shop-by-category/roll-up/bak-revolver-x2-tonneau-cover.html
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
