Lift question
I have a 14 silverado ltz z71 and I'm looking to lift it 3.5". I'm debating on running either 18s or 20s with bigger tires. I seen all different sizes of tires that will fit with each wheel without rubbing or cutting. I'm trying to run the biggest tire possible without rubbing or cutting. I was told with 20x9 wheels with a 18mm offset I can only run 285/55/r20 tires. That seems small to me, about an inch bigger then my stock 265s. If that's true do i run 18s so I can get bugger tires then? Help!
Search, tons of information and threads on this same subject with lots of different info and subjective views. So many variables, the best bet is to gather as much information as possible and decide as what might not rub for someone might rub for another. Tire aggressiveness, size, alignment, lift type, back spacing, width, ect play roles. You won't get one good solid answer in here without it being small and on the safe side. There are guys that run 34's on a small level and swear it doesn't rub and just the other day a guy posted his stock truck was rubbing. Look around, this is probably the most common question out there so lots of info.
Good luck.
Tyler
Man I had the same want's/needs and went with 18" wheels to get bigger tires... look up my posts. It just looks OFF to me and to many.
I haven't posted my fix yet, but I sold the 18" wheels and tires and went back to 20" 305/55/20 and WOW! MONSTER difference!
The 18's just made the truck look like it went to the gym and worked out for months, but never did legs! It just looked off. That big of a truck needs those bigger wheels. In my opinion anyway. Search my posts...
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
