If I have install shortys without a tune right away will the truck be bogged down? I already know it'll throw a code from the EGR valve, but will I feel a difference in drive quality?
You're not going to feel much of a difference with shortys either way, you're better off with long tubes. but to answer your question, you may see some codes( I do on mine) and i'm sure you will notice a slight difference but i doubt it will be much.
I'm probably not the guy to answer that but every vehicle is different with everything around it being different, engines, exhausts, etc.
How big of a difference in torque and hp is it between the two. Do you know?
I just got shortys installed on my 05 5.3 and it didn't throw any egr codes. I feel a good amount of power but not an overly crazy amount. I also think it sounds great!
