Grinding noise in front end. I've done everything!
I have a 2005 Silverado with 130,xxx miles. I love the truck and have babied it since I bought it about a year ago. When the truck is in 4x4 or auto 4x4 it will make a grinding/rubbing noise in the front of the vehicle. It sounds like the front drivers side. I have had new bearings put in the front diff, new fluid in the diff and t case. new encoder motor, new wheel bearings, and new cv axles. what am I missing here? the noise goes away in 2wd almost instantly but when in 4x4 it comes right back. I am going crazy trying to figure this out. The only part it seems I have left is the 4x4 actuator in the front diff. could this cause a grinding concern?
I have to ask if this is your first GM 4WD?
No. I have a 95 and you cant even tell its in 4wd when you drive it. this one I can feel a groan in the front end as soon as I engage 4wd. and messing with it at lunch it is just slight around 30 mph but you can feel it. and then when coming to a stop it gets louder. is my whole front diff going out?
This one does not make sense. Might be time for a test drive with a local differential shop guy. A good one can tell you what is going on right away after a test drive. Much easier than a post description.
Interesting you said 95 as that truck had a different heated engagement system from the factory that took much longer to fully engage and resulted in not hearing 4WD noise right away. Many of these trucks were upgraded to the mechanical engagement system that resulted in more noise right away as it fully engaged in a few seconds.
I have a 96 K1500 that was exhibiting these same symptoms about 4-5 months ago. My truck was experiencing some bucking when first starting off and then everything would be fine. No real noise in 2WD but when I would put it in 4WD It would buck even worse and I had an obnoxious grinding noise. I ended replacing the transfer case and all my 4WD grinding noises went away. I still had some grinding after the T-case was installed and about 150 miles later my transmission went out. Could be a number of different other things as drive line noises can fool you because sometimes they may be coming from a totally different area than where you think they are coming from. Some 4WD noise in a GM is normal. If it is truly a "grinding" noise then you have an issue for sure. One way to find your issue is to jack your truck up and put it in 4WD. Then put the transmission in neutral and remove the driveshafts (if you are sure the noise is only coming from the front then just remove the front). With it jacked up you c an spin the front differential and listen to it. If the grinding noise you are hearing is coming from the front end components you will hear it while spinning the differential. If everything sounds normal then I would probably start looking into the T-case. Sometimes the chain in the T-case can get loose and it will make some noise. When you changed you T-case fluid did you look to see if there were metal shavings in the fluid?
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
