Issue with LED turn signals
Hey All- Hoping you guys can help me figure out why my right turn signal on my Anzo tail lights works intermittently.
The left side works just fine.
The right tail light works just fine if my battery voltage is above 14. If it is below 14 it flashes rapidly and tells me its not working.
Does anyone know an easy fix for this problem?
Thank you!
What OHM resistor are you using? Needs a 50w 3ohm.
The resistors were wired in from anzo. Never installed anything else. I just find it weird it works on the left but not the right. Can I buy a new resistor and just wire it in to replace the current one?
following. Its rare but sometimes I have this same issue with my driver side lights. It tells me that both the front and rear have failed but if I get out everything is working fine
The crazy thing for me was I put the lights in at the end of last summer, which is when I first noticed the issue. Then all winter long the battery was operating above 14 so it worked just fine. But now that it's getting warmer, the battery is operation below 14 and I'm having the issue again.
  • 4 weeks later...
If your resistors have a bad connection you'll get an intermittent failure. Had it happen on my front driver side. Double sided tape came loose causing the movement to make a bad connection
Sent from my SM-G930V using Tapatalk
it's not really intermittent its just when battery voltage is below 14
    juggernautusa
    juggernautusa
  • Who's Online   0 Members, 0 Anonymous, 386 Guests (See full list)
