Confused HID issue
I truly know your frustration, anger and disappointment!!! lol When they work it is all worth it in the end, Trust me it is! Does your Harness have to Relays on the harness on the passengers side?
Yes it has 2 relays, one for each side. It's the Morimoto elite kit
I verified it was the ballast before I installed the harness and indeed I have a bad ballast. I just rechecked all my connections including the grounds. Nothing changed. If the truck is off, the lights come on. If the truck is running, they don't. If I turn the lights on before I start the truck, and start it with them on, they will stay on, but if I turn them off they won't come back on. I called TRS support but it was 10 min before they closed. They said it sounded like a polarity problem and to reverse the pins for the capacitor (just plug in backwards first to check). I tried this and it made no difference. I'm completely baffled. Could it be a bad relay?
Yea I think they may have misunderstood what you were trying to tell them. If it's a polarity issue then you would not get any light at all. It could be a bad relay but I highly doubt it since they are working sometimes. Since you only have one working ballasts why don't you try swapping the relays and see if that makes a difference. Assuming all connections are good the only reason the HID lights wouldn't work is if the relays are not getting enough voltage to activate.
I'll have my new ballast tomorrow so I'm going to leave it alone until then. What could cause the relays to not be getting enough power?
The only thing that would cause them to not get enough power would be the stock input harness. I have a 2015 Sierra and I haven't taken it and had the TSB for the headlights done and I don't think it was done either because I still had Philips bulbs in my stock housings when I installed the first HID kit. Only other thing I can think of that you can do to ensure that the HID kit is working properly (once your new ballast comes in) is to test the harness by pulling power directly from the battery to activate the relays to make sure the HID relays fire correctly.
Well the harness is connected to my battery so isn't it already doing that? I checked the build date on my Sierra and it was post-TSB. My lights were working for a month 90% trouble free before I installed the relay harness, so the OEM input shouldn't be the issue.
The harness is connected to the battery but the clean power from the battery has to travel through the relays before going to the ballasts. The stock input is what activates the relays and allows the power from the battery to travel to the ballasts. If the voltage from the stock input is not enough to activate the relays then you would get no power or the relay could be bad and not activating at all. I wouldn't think that is the case since you have stated that the lights function when turned on manually while the vehicle is off. Electrical issues are difficult to diagnose without seeing the issues in person.
When you say that your lights "were working for a month 90% trouble free before I installed the relay harness, so the OEM input shouldn't be the issue" are you referring to the stock halogen headlights were working or your HID's? If you are referring to the stock headlights this is possible since they are halogen and can operate at a voltage lower than 12V.
The HIDs were working plugged into the OEM outputs. I say 90% of the time because maybe 1 in every 10 times the passenger side wouldn't come on and I'd have to cycle the light switch a few times before it did. This is what I think caused the ballast to burn out. And as I'm typing this is occurred to me that I have the relay harness plugged into the passenger side OEM output. Maybe I should try it plugged into my drivers side. This would be so much easier if getting to the passenger headlight wasn't such a hassle on these trucks.
Yea I don't know. At this point I would plug the factory bulbs back in and verify that things are working properly with the factory setup. I'm sure it will but at least you would know for sure where the issue lies. But, since your new ballast comes in today I would only check that after hooking up the new ballast and if you still have problems. Question: I see that you have an SLT listed under your name so do you have the LED DRL strips?
Well just put in 2 new ballasts and 2 new igniters and everything is working like a charm. I removed and reinstalled the entire harness and kit, so I have no idea what was causing the problem but it seems to be solved. Fingers crossed!
Glad you got things straightened out. I'd still love to know why you were having issues, unless both ballasts were actually bad, then that would explain everything.
I'm quite curious as well. Especially since last night I wound up having to take my wife's car to work because none of the lights would come on and the buzzing noise randomly started. Now no noise and no issues. I wonder if all my fiddling made the second ballast go bad.
NV no telling what the actual problem was but the Moron who did work should've installed everything from get go. If he was unsure of what to do TRS is a phone call or online chat away. Hope you don't send or recommend any work to him in the future. Feel you did a good thing in reinstalling the harnesses.
Yeah I'm really pissed at the original place. I hadn't realized he didn't install the harness until a few days later. He gave me a box with my "extra parts" but I thought it was just my LED's in it otherwise I would have told them right there to install the harness before I take my truck. My buddy uses them for all his vehicles (he's got 6) and knows the installer personally. He said he was really surprised and that's unlike him, but after talking to him after the first time my passenger light didn't turn on I just don't think he's up on the latest tech and knowledge with these lights.
    tblt44
    tblt44
  • Who's Online   7 Members, 0 Anonymous, 776 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
