Dominator d2 nerf bar
I don't have these but seriously interested in picking these up. Debating between these, Rough Country and the NFab. They all have a similar look. Probably see which pair will have the best deal on Autoanything or a similar site. Let me know what kind of pricing you find. The Dominator set is about 330$ on Amazon. Not bad...
AutoAnything with the 20% off promo is 292 at the moment
Very tempting!! I wish they had a wheel to wheel version with bed access or even just a wheel to wheel version without access. I only see a cab length one. Do you see other versions anywhere? I can't tell you how handy that bed access is! The code does not work with any of the Nfab bars...lame!! I do like these though and it is a good price...hmmm
These are the Nfab ones I want
https://www.amazon.com/N-Fab-C1495CC-6-Nerf-Step-Bar/dp/B00FMIZ9AQ/ref=sr_1_47?s=automotive&ie=UTF8&qid=1491579613&vehicle=2014-47-491-478-128-53-6--18671--8-1-2676--1-0&sr=1-47&ymm=2014%3Achevrolet%3Asilverado+1500&keywords=nerf+steps
I just bought some magnum bars that wifey didn't like so they're for sale cheap If anyone is interested lol
Sent from my Nexus 6P using Tapatalk
Pics or model?
I had a post a week or so ago comparing the N Fabs and Rough Country nerf bars. Sounded like they were made by the same company and appeared to have some issues with rust from a few members after a short period.
I have read that as well. I went with the dominator D3 textured black. I didn't see as many complaints on rusting for these but everyone seemed to say their customer service is awful. The D3 one cover wheel to wheel and have truck bed access. Got them for 370$. I'll post pics when I get them installed.
I went with the D3 ones for 370$. Did you end up picking up a pair?
Haven't pulled the trigger yet. Getting my wheels and tires Monday so I'll have a better idea of what my trucks going to look like
How much?
Send me a pm with location? Shipping will be the biggest issue but we could figure that out
    C. Hart
    C. Hart
  • Who's Online   4 Members, 1 Anonymous, 608 Guests (See full list)
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
