I want to remove the plastic air dam on my front bumper. I already removed the lower most dam but I am still worried that the upper air dam is going to get hit when I head in the woods.
Have any of you fine people tried this Kit? http://store.sdhqoffroad.com/2016silverado1500skidplatesystem.aspx
I would have to undercoat it black as I have a Midnight and adding that much shinny would look silly.
Just wanted to know if this is a quality part and or are there better ways to fill in the gap left in the center of the bumper when removing the upper air dam. Any thoughts and or pictures would be helpful. Thanks in advance.
The SDHQ skid plate looks like a nice piece. I built this piece for mine and added the GM aluminum skid plates to replace the plastic splash shield.
1914C7B0-05C6-4B2A-8D4D-3831581B939E_zps
50C3E094-7D89-4585-ADEF-39DD271977FB_zps
I like that MUCH better. Could you post some detailed pictures?
Edited by MrSteam
  • 4 years later...
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
