let me see your bikes!!!
THE BIGPUNN
i saw a katana today, and man was that nice. i was counting my pennys to see if i could afford another vette, but after seeing that bike....wow! anyway, i figure bikes are cheaper, less insurance, less space-easier storage, less maintanance, easier to park, less gas, faster :D ! cant decide between a 750 or 600. i was thinking instead of a '02 maybe '94 or newer. pics and advice appreciated.
I have a '93 Yamaha GTS 1000 that I bought in '95 w/5k on it.  I have 40K on it now and it still runs great.  I will be getting a new FJR1300 next year (I hope).
I'm sure this'll start a war, but I'm not a fan of sport bikes.  Probably because if I owned one, I'd be 6ft under already.
This is what I'm planning on buying late spring, early summer
Bigpunn, I used to have a Katana 750, a much bigger bike than the 600. That was my second bike and it was much better than anything I had ever ridden. I'd get another one in a heartbeat if I had the chance.
If I were toget into Motorcycles, I'd rather have either a Harley or a Valkyrie (forgot who makes those).
Off the topic but on the same subject, Is it very hard to keep your balance on Motorcycles?
Here is a pic of the FJR 1300 that I mentioned in my earlier post.  They will be released stateside in August.  I will sart looking at them  next year.  145 HP and hard bags to carry my gear in...  Yea baby!!!
Ohh I love bike.  Don't get a katana tho.  They are not really that good.  Have you ever ridden before?  I want to get either an r6 or a cbr f4i!!
Hey Mark?  Is the r6 your or your brothers?  I didn't know you rode bikes!  Thats awesome!
Shaners that bike coming out in August looks great.
FSC my brother had the predecessor to that blue R6, I want to say it was a R600 or 600R, it was a really nice, really really fast bike.
I'm not so sure I want to get a supersport bike, I'd probably get myself killed.  I've been to way to many motorcycle accidents where they are DOA.  I'm probably going to get a 500-600cc dirt bike in the future.
Joe
I just can't stop drooling over that new FJR1300.  You guys are going to cost me some serious ca$h!!!  LOL
I sport/tour because there are no good roads around here to ride the twisties.  So when I leave home I'm usually gone for 3-5 days...  This bike will do it all.
I don't have one, but a friend of mine has a R1 Champion Edition.  He's polished the frame on it and lots of other cool stuff.  He's actually polished several peoples frames around here, and one guy mailed his frame to him from Minnesota (I think it was MN).   Here's a link to his page: Extreme Polish
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
