Weathertech mats
Since you replaced your all weather mats with your Weathertech mats would you happen to have the OEM mats collecting dust in your garage? I wouldn't mind taking them off your hands lol
This may sound crazy but I'm using the OEM ones on top of my Weather Tech, I do a lot of trail running and it's way easier to grab the mat and spray it off vs fighting to get the WT out of the truck. With this setup I never remove the WT.
  • Replies 37
I've had WT in another vehicle and even now have the WT in-channel window guards.
I have the Husky x-act in this truck and love the way they fit and how secure they are under foot.
I've been of the (amateur, not counting my MBA) opinion that WT spends disproportionately on promotion/advertising and not nearly enough on product quality. And product was what got them in the game initially.
Well I made up my mind and the weathertech mats were ordered this morning. I will be sure to give everyone an update on the fit and finish of the product when they arrive.
Hey everyone I recieved the mats on Friday and got them installed yesterday. As far as fit goes they match to the contour of the truck perfectly. As far as finish goes they look great but the front driver mat has a scratch in top left corner but you can't even see it when it's in the truck so I'm ok with that. They aren't as thick as the gmc mats but they provide more coverage so that's a plus. I will post some pictures soon.
Did you get the full mat in 2nd row or the half mat?
If you got the half mat in 2nd row can you provide pics of the fit near the factory storage box?
ty
It's not - WeatherTech all the way........
you see the top left corner of your mats how it's a little bit off of the interior frame of the door? yeah that's the beginning of what happened to both of my sets. It ended up getting super warped it really sucks and there isn't much you can do. Perhaps it depends on the climate you live in. I even tried putting them out in the sun and then reforming them a bit to fix but it was too late.
I'm happy with the rubber type of weathertechs I have for now but they don't have as much coverage, next time I'll go with the Husky's for sure.
In my last 4 vehicles I've had, I've always went with WeatherTech. This time around it might be different, if they're actually cheaper I just might go with the Huskys'. My only concern with the softer rubber, wouldn't cleaning them be more harder? Lint, dirt, etc will stick to em?
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
