Weathertech mats
Hey everyone! I just recently purchased a 2017 gmc Sierra ccsb. I plan on ordering some new mats for the truck and weathertech is the one. The question I have is in the rear I have the underseat storage box and wanted to know if it will work with the full mat or do I need to order the half mat due to me having the box under the seat.
  • Replies 37
Don't rule out the husky mats. Weathertech's QC has gone downhill lately. If I had to do it again, I'd have the Huskys.
I have huskys in the fronts and weathertechs in the rear. I ditched my weathertechs for the front because they slid around too much and channeled all the mud and water onto the door sill. As cbrsilv15 said, the weathertechs quality seems to have gone downhill. They warp more and dont fit like a glove. Go with Husky X-Act contours.
My 2017 CCSB Weather-Techs fit fine and tight. Have cleaned them 3 or 4 times already - easy to get out - secure to snap back in...... See them installed at post #93 here:
http://www.gm-trucks.com/forums/topic/196751-2017-max-trailering-built-to-order/page-7
Couldn't agree more. I actually compared the thickness of the wt liners purchased back in 2008 for my wife's enclave to ones I bought some months ago for my 2016 sierra.
Wt denies it, but take calipers to the material thickness between the two and the results speak for themselves.
Also, the material formulation has clearly changed.
The newer ones warp, don't fit snugly and don't meet up to the quality they had in 2008.
Will be replacing soon. Regret this purchase. Had them for my 2007 sierra, and they were great as well.
Another fine product that faded into the sunset imo.
Sent from my STV100-1 using Tapatalk
I also wish that I hadn't gone with the weathertech fronts, I had to take a heat gun to reshape them to fit. No real problems with the rear full mat and my Duha storage though.
I have the full sized Weathertech mats in the front and rear and love them. I have my new Kicker sub on top of the rear mat with no issue, so I'd guess the storage box would be no different. I love my Weathertechs.
Husky liners, less expensive and better quality. American made for a Mexican/American truck!!!'
I have the Aries mats. They're a different type of material...They call it thermoplastic rubber. Check them out. They fit well and seem to do the trick. I haven't had a 4yr old throw up a red 96oz big gulp on my floors yet, but my weekend plans might get something spilled on them if I'm lucky. Were better priced too.
The truck has the GMC oem all weather mats but I'm not really a fan of these. I had weathertech in my 2013 f150 crew cab that I traded in and the fit and finish with them were perfect. They looked new even after being in the truck for 3 yrs that I owned it. Now I have to decide between the weathertechs or the huskys. Yall are making this hard for me lol
We had the "laser cut" weather techs in the front of our suburban after a while they get warped and become more of a pain in the ass. I replaced them once with another set up front wondering if we did something wrong or didn't take good care of them and it happened again. The next time we ordered the rubber (and much cheaper) version from weather tech for the front and are super happy with them. I will also say I have the rear seat weather techs in both our suburban and the silverado I think it's great in the rear for full coverage and have experienced no movement or warping
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
