DL3 Mirrors with/without Auto-tilt
New to the forums, sorry if this is a redundant post. I've read through probably 100 power mirror threads all around the interwebs, but it's been difficult to track down a straight answer to my question/situation. Hopefully it's a simple yes/no, and we can archive this thing for future reference.
My truck has FOB DL3 mirrors from the factory, but does not have the memory seat option.
What do I need to enable aut-tilt in the DIC?
A) Have a dealer or somebody with a Tech II/GDSD2 flash the BCM to enable "memory seat" (A45?) option
B) New wire harnesses
C) Both
D) Something else??
For the sake of successful searches:
LH 23180074 & RH 23499472, LH 23171577 & RH 23171579, 15906881
Contact pgamboa. He has done TONS of work on the various mirrors and has most of the schematics figured out. If you send him your info and some pictures of the connectors he can probably help you out. He also has quite a few threads on here about the different mirrors.
Pgamboa can help with the dl8 to dl3 mirrors, but not this. It is all controlled by the bcm and last time I heard, it cannot be added to the software. Are you sure there's not a setting on the info screen if you already have the DL3's?
This is right... I have no knowledge of the requirements for auto tilt as this is a feature in the cluster.
In my conversations with GTPrix, at this time, it seems like there is more to it and that might be hardware dependent (Seat Memory Module and having A45). The OP is one of the few that has DL3 Mirrors Minus the A45 Seat Memory option. I find it odd on one the harness part #s though as I have 23171579 as a DL8 Harness. So I am a little confused on how the DL3 is fully functional (lighting portions that is) as is.
I wish I had more information for ya. But anything with the cluster options (auto tilt reverse, FOB Mirror Fold In/Out) are outside of my research... at the moment... :)
Thanks guys.
To be clear, those are not MY part numbers - they're just PNs I pulled out of other threads with vague thread titles.
My truck is a 2014 Sierra All Terrain. I think I have DL3? My mirrors do have power fold and turn signals, but there is no option for auto tilt in the US. I also haven't been able to find a memory seat button anywhere
Your memory seat buttons would be on the trim panel, right above the handle to open the door if you had the memory seats.
Thanks guys.
Look in your glove box RPO list. If you don't se A45 listed, your don't have Seat Memory. If the option for reverse tilt is not in your settings options in the radio, you don't have it. This is fondupot's video showing that. That feature might be dependent on the Seat Memory Module which doesn't sound like you have.
https://youtu.be/tl659iqfFV4
    juggernautusa
    juggernautusa
  • Who's Online   1 Member, 0 Anonymous, 444 Guests (See full list)
