I felt like a little celebration...
This is my truck leaking... found this out last week. Just picked up a condenser from a dealer as they were the only one I could find in my area that actually had one. $400 for the part and two seals...
Should not have cost you anything. Did GM turn down covering this leak?
Probably going to jinx myself with this, but my 2006 AC hasn't been touched. Not terribly confidence inspiring that they can't build a pickup to hold freon after a couple years now.
That said, great diagnosis and fix. Wish I was more capable concerning AC.
Sent from my SM-G920V using Tapatalk
I agree also with you,my 2006 silverado A/C was super cold. When I sold it it was over 9 years old and never been touched. The guy that bought it could not believe how cold it was. My 15 Sierra not near as cold.
I recall my father's 68 Olds having frost on the metal vents while we rolled down I-40 in the 100F desert in Arizona. The old GM R-12 systems were hugely oversized and had more like refrigeration capability.
My 1999 GMT800 R-134 system worked very well. It wore out the compressor clutch eventually around 150,000 miles. I changed the compressor and lines. It still works and has to be around 300,000 miles with the current owner.
My 2008 GMT900 R-134 system worked well for about 4 years/100,000 miles until it quit working in 105F heat passing thru Yakima on a week long trip 1000 miles from home with two dogs and my wife. I could get it to come on for one cycle until it cycled off and wouldn't cycle the compressor again. While my wife was understanding, she expressed a desire for me to get it fixed. Given that our entire trip had been in a heat wave across the west, I didn't see finishing the trip without AC. 5-10 minutes later, I found an auto parts store. I pulled in, popped the hood, and verified the clutch would only engage if I shut the system off and turned it on again. When it cycled the compressor off, it would not engage again. I was pretty sure it indicated a marginally low charge. I went in asked for a can of R-134, a charging hose, and a paper clip. I jumped the pressure switch with the paper clip, connected the freon can, and added 12 oz ( blindly without gauges, only guessing the charge) 10 minutes later, we were on the road with a great work AC. When arriving at home, I checked for leaks, replaced hoses, and recharged. It still works.
The GMT-800's had one of the best AC systems GM ever produced. The evaporator, compressor and condenser were over sized because of 134a and there was no concern to save fuel with a smaller compressor. They last forever and have no issue blowing at 40F in 100F weather.
Need the cooling capacity for those luxurious rear vents :driving:
Sorry, I had to. If only I had cooled seats too.
Ehhh, they covered a little. The cost to replace the condenser is around $1600... GM covered around $1,000... I had to pay $560 out of pocket. The condenser and the seals from the dealer (which was the only place to buy the condenser) cost me $400. So I had them replace it as it would not have cost me much less to replace it myself. Less than I expected but more than I would have liked to pay.
    1981dustin
    1981dustin
  • Who's Online   4 Members, 0 Anonymous, 1,598 Guests (See full list)
